What is the Hypermesh TCL API to hide menu box and TCL console?
hm_framework setcmdstatus 0 will hide the tcl console.
What do you mean by menu box? Maybe share an image.
Hello Ben, I tried this API, but its not working, as you could see in the image below after running this API also, the tcl console is not hiding
@Ben Buchanan, The menu i meant is shown in the image attached. Do you know the API to hide this menu
I was working in the new interface. Let me dig some more and see if I can find something for classic.
I wasn't able to find anything for classic. Any way you can switch to the new interface? I suspect since the panel is so integral to classic there will not be a way to get rid of it in an api. Also the console in classic is always there but can be collapsed so there might not be a way to get rid of it through an api either.
Hello again Mr. Ben
i tried the command "hm_framework setcmdstatus 0" in the new interface of Hyperworks 2023.1. Still iam getting an error:
Can you help me out with this issue to enable tcl console in the HWX interface?
