Assign coordinate system
Enrico_20294
Enrico_20294 Altair Community Member
In the model I am working to, grids are referenced to a local coordinate system, which is previously defined.
Is it possible to assign the global system to the grid reference?
If I go to Analysis>System>Assign I cannot find how to select the global system.
Thank you very much for your help
  • tinh
    tinh Altair Community Member
    edited November 2017
    uhm, there should be an 'unassign' button to do that
    you can select the nodes then enter below command:
    *systemsetreference nodes 2 0; # 0 is id of global (basic) system
  • Enrico_20294
    sorry, I didn't understand
    I usually use this panel to set the local reference system, but I do not know how to select the system 0
  • tinh
    click menu View>Command Window
    select nodes then enter above command
  • Altair Forum User
    Altair Forum User
    @Enrico
    If the local system is useless, Delete it simple :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Enrico_20294
    Thank you very much
    Enrico
