I had modelled my rotor blade with composite properties. While attempting to do a modal analysis using HyperWorks (Optistruct) as per the tutorial from Altair on YouTube, my modes were shown at extremely low values. I tried all possible variations but still, the modes are not appearing at higher values as expected for a regular rotor blade. The mode shapes generated are also not reflect anything on the overall rotor body movement.
Base model with All DOF constrained at the root
Result of modal analysis
For example the mode shapes of first 6 modes and mode 8 and mode 9 are like this with 0 magnitude (Real Eigen modes)
Mode 7 and 10 are like this but slightly different magnitude
Any help is highly appreciated.
Thank you for your time and expertise.
Regards
Ananthan
