Nano fluid is not installing in windows properly and 2022 is available only for linux we tried 2022.1 . but its java error for windows . plz help us or tell the proper to install this ...please
The 2022.1 CFD Solvers package generally does work on Windows - including nanoFluidX.
Which is your Windows version? Which NVIDIA GPU/Graphics card do you have on your Windows system?
yes nvidia getforce GTX actually its showa java error when install the set up file.
Are you getting the error when you double-click the actual installer package
hwCFDSolvers2022.1_win64.exe
Is that what throws the error?
Things to try:
1. Move that installer .exe file to a different directory under \ - rather than in itself2. Download again and try again
