Hi
I have been simulating an antenna in Feko (MoM & FEM) & CST (FDTD) . The peak gain variation w.r.t. frequency has been different for the antenna in Feko & CST. In CST-FDTD there is a setting by which the distance between the antenna structure & the PML ( perfectly matched layer) can be changed. The default value for this parameter is wavelength/4. ( wavelength can be centre, monitor or user defined). Also, the estimated reflection level is adjustable. The default value is 1e-04. At the default values the CST peak gain w.r.t. freq. differs from that in Feko. But when
a) the distance between the antenna structure & the PML is reduced or
b) the estimated estimated reflection level is reduced or
c) distance between the antenna structure & the PML is increased AND the estimated estimated reflection level is reduced
the peak gain behavior in CST matches reasonably well with Feko.
I am trying to understand this phenomenon. Is there a similar mechanism in Feko far fields calculation which employs a PML at a certain distance from the antenna structure? If yes, what is that distance and what is the estimated reflection level?
