Can 2 rigids have the same dependent nodes?
RodrigoFST_22268
RodrigoFST_22268 New Altair Community Member
I'm doing an optimization to a rim centre. I defined multiple nodes to simulate different points of the contact patch. I connected the nodes with the washer area using rigids (RBE2) elements.
The problem is that when I run OptiStruct it gives the error #723. After some research I saw that it's because different rigid elements have the same dependent nodes. However I need them to have the same dependent nodes.
How can I connect the different nodes to the same area without having this problem?
Thanks!
  • Altair Forum User
    Altair Forum User
    edited September 2017
    Maybe with coincident nodes you can connect but to understand the problem, can you share the model file please?
