Dear All,
I wants to get pretension load value along with node details on which load is applied.
Can we get it directly by using tcl\tk code.
@tinh Please suggest if any api avalailable.
Best Regards,
Vikas Kumar
Hi
Give a node id, find attached load by *findmark
Then get load value (please check dataname in hm reference help I don't remember)
@tinh can you help me with dataname.
I am unable to understand syntax. How to use that.
Pls give one example here for above problem in free time.
How we can get card edit value for all material group member using tcl\tk.
Hi all,
I need help regarding getting card edit values as shown in fig 1 by using tcl\tk.
Fig 1
So it will display all information as shown in Fig 2. All i need is, this value in a list or anything.
Fig 2
Another help i require to get 'XRef Entities' as shown in FIg 3 so it will display again a reference like Fig 4. I need to apply again Xref Entities on same. So i need reference list in a variable.
Reference list is marked by red color. I need to follow this process only.
@tinh or @Imoto please provide tcl\tk scripts for above cases.
I am using abaqus profile (standard 3D) in HM..
@tinh can you help me with dataname. I am unable to understand syntax. How to use that. Pls give one example here for above problem in free time. How we can get card edit value for all material group member using tcl\tk. Regards, Vikas Kumar
Dataname for force value is magnitude
hm_getentityvalue loads $loadid magnitude 0 -byid
For card editor fields, use attribute name instead of dataname:
hm_attributelist mats AL name -byname
Hi all, I need help regarding getting card edit values as shown in fig 1 by using tcl\tk. <?xml version="1.0" encoding="UTF-8"?> Fig 1 So it will display all information as shown in Fig 2. All i need is, this value in a list or anything. <?xml version="1.0" encoding="UTF-8"?> Fig 2 Another help i require to get 'XRef Entities' as shown in FIg 3 so it will display again a reference like Fig 4. I need to apply again Xref Entities on same. So i need reference list in a variable. Reference list is marked by red color. I need to follow this process only. <?xml version="1.0" encoding="UTF-8"?> @tinh or @Imoto please provide tcl\tk scripts for above cases. I am using abaqus profile (standard 3D) in HM.. Best Regards, Vikas Kumar
@tinh Suggest for XRef
Hi Vikas
data names and attribute names have unique type
for data names, search their type in reference help
for attribute names, get their type by hm_attributetype, hm_attributetypename
if the type is 'entity' => that data/attrib is an X-ref
using hm_attributeentity... to retrieve X-ref data
Hi @tinh,
I am using this code
foreach attr [ hm_attributelist mats 'AL' name -byname] { set attrValue [ hm_attributevalue mats 'AL' $attr -byname ]; set x [hm_getvalue mats id=1 dataname=$attr] set y [hm_attributetypename $attr] puts 'attribute: $attr attrVal: $attrValue val: $x attributeTypename: $y' }
Marked line always returns string, integer but not entity at all.
I am using abaqus profile.
For particularly x-ref i am not getting any idea.
Output:- attribute: ABAQUS_MATERIAL attrVal: 0 val: 0 attributeTypename: integer attribute: Num_Comments attrVal: 3 val: 3 attributeTypename: integer attribute: Comments attrVal: 3 val: ===================================== { AL} ===================================== attributeTypename: arrayofstring attribute: CommentEnumField attrVal: 1 val: 1 attributeTypename: integer attribute: UseElasticCard attrVal: 1 val: 1 attributeTypename: integer attribute: ElasticTypeEnumField attrVal: 1 val: 1 attributeTypename: integer attribute: ELASTICDATACARDS attrVal: 1 val: 1 attributeTypename: integer attribute: Young attrVal: 1 val: 70610.4 attributeTypename: arrayofreal attribute: Poiss attrVal: 1 val: 0.33 attributeTypename: arrayofreal attribute: TempE1 attrVal: 1 val: 0 attributeTypename: arrayofreal attribute: Elastic_Num_Comments attrVal: 1 val: 1 attributeTypename: integer attribute: Elastic_Comments attrVal: 1 val: -------------------------- attributeTypename: arrayofstring attribute: UseExpansionCard attrVal: 1 val: 1 attributeTypename: integer attribute: Thetanot attrVal: 20 val: 20 attributeTypename: real attribute: Expansion_UserEnumField attrVal: 3 val: 3 attributeTypename: integer attribute: ExpansionTypeEnumField attrVal: 1 val: 1 attributeTypename: integer attribute: Expansion_OptionalEnumField attrVal: 1 val: 1 attributeTypename: integer attribute: EXPANSIONDATACARDS attrVal: 17 val: 17 attributeTypename: integer attribute: Alpha attrVal: 17 val: 2.17e-005 2.2e-005 2.23e-005 2.27e-005 2.31e-005 2.33e-005 2.36e-005 2.38e-005 2.4e-005 2.42e-005 2.44e-005 2.46e-005 2.48e-005 2.5e-005 2.52e-005 2.54e-005 2.56e-005 attributeTypename: arrayofreal attribute: TempAlpha attrVal: 17 val: 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 300 320 attributeTypename: arrayofreal attribute: Exp_DependExist attrVal: 0 val: 0 attributeTypename: integer attribute: Exp_Depend attrVal: 0 val: 0 attributeTypename: integer attribute: Expansion_Num_Comments attrVal: 1 val: 1 attributeTypename: integer attribute: Expansion_Comments attrVal: 1 val: -------------------------- attributeTypename: arrayofstring attribute: UseConductivityCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseSpecificHeatCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseDensityCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseDampingCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseDielectricCard attrVal: 0 val: 0 attributeTypename: integer attribute: Elastic_Depend_Exist attrVal: 0 val: 0 attributeTypename: integer attribute: Elastic_Moduli_Exist attrVal: 0 val: 0 attributeTypename: integer attribute: FailStress attrVal: 0 val: 0 attributeTypename: integer attribute: FailStrain attrVal: 0 val: 0 attributeTypename: integer attribute: UseHyperelasticCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseHypoelasticCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseHyperfoamCard attrVal: 0 val: 0 attributeTypename: integer attribute: MullinsEffect attrVal: 0 val: 0 attributeTypename: integer attribute: UsePiezoelectricCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseViscoelasticCard attrVal: 0 val: 0 attributeTypename: integer attribute: CAST_IRON_PLASTICITY attrVal: 0 val: 0 attributeTypename: integer attribute: UsePlasticCard attrVal: 0 val: 0 attributeTypename: integer attribute: UsePotentialCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseCrushableFoamCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseCrushableFoamHardCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseRateDependentMatCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseCreepCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseAcousticCard attrVal: 0 val: 0 attributeTypename: integer attribute: User_Output_Variable attrVal: 0 val: 0 attributeTypename: integer attribute: UseUserMaterialCard attrVal: 0 val: 0 attributeTypename: integer attribute: UseDepVarCard attrVal: 0 val: 0 attributeTypename: integer attribute: DEFORMATION_PLASTICITY attrVal: 0 val: 0 attributeTypename: integer attribute: MatDamageInitiation attrVal: 0 val: 0 attributeTypename: integer attribute: Mat_UnsupportedCards attrVal: 0 val: 0 attributeTypename: integer
Thanks,
Which attribute is entity?
Hi @tinh
Here not even single attribute type name is coming as entity.
But i want this details as mentioned before also (Refer Below image).
Data marked with red rectangle i needed.
Manual process i have shown in image.
Thanks
Try
*createmark props 1 'by material name' AL
You get 2 props, easily get their names and ids and types
In this case it is working. Because here we know that both is a property entity.
But in case of any other entity attached with this material in that case we need to find out.
Can we find out all attached entity along with this material name in one shot.
Thanks for your help.
you can make a loop through all hm entities and check if severals attach to that material. it is a simple task.
