Hello everyone
I am currently comparing different FE models and their effect on computational time. My models consist of simplified screws (rigid bodies) inserted into a bony cylinder. I have two parameters, which I change in my models: E-modulus and interface type. Apart from this, the models are always identical. I have compared the following three models:
- type 2 interface, low E-modulus (Model 1)
- type 2 interface, high E-modulus (Model 2)
- type 7 interface, high E-modulus (Model 3)
The simulation time for model 2 is about seven times longer than for model 1 and three times longer than for model 3.
The nodal time step for the models with type 2 interfaces is always determined by the master node of the rigid body.
I run the models in RADIOSS.
Now, I have the following questions:
1. Why does an increase in E-modulus lead to such a high increase in simulation time (or decrease of the nodal time step) for the models with type 2 interface?
2. What is the difference in the calculation of the nodal time step for type 2 and type 7 interfaces?
And why is the nodal time step higher for the model with the type 2 interface when compared to the same model with a type 7 interface?
Thank you already in advance for your help.
Best regards,
Gabriela
