I am facing the error 1908 so kindly help me to solve the problem
Thanks and regards
Mahantesh
Could you please share .out file of the run? Also refer below post.
Hello Sir,
I am not getting the error so i attached the .out file so kindly go through it
Mahantesh T
Please dont call thermal bc under Load subcase definition for strutural loadstep. Instead apply thermal bc via subcase option TEMP_Load.Also define elastic material property to run through.
Elastic material properties like E and Poisson ratio i assigned in material load col, now the file is running but the results r coming wrong, so kindly guide me is there any other options are there to assign elastic properties
I guess this could be because of units defined. What value you have defined in MAT1 and MAT4?
You can request free eBook on OptiStruct Thermal Analysis using below link.
https://altairuniversity.com/free-ebook-thermal-analysis-with-optistruct/
Thank you sir
I am facing the error 1908 while carrying out the simple thermal analysis for simple beam so kindly help us to solve this error and please find the below attached file regarding the problem
Thanks and Regards
I am facing the error 1000 and its showing the temperature error but i have assigned it so still error is coming so kindly help me to solve the error
Please refer below post.
I am facing the error MATi data present, but there is no TABLEMi, kindly guide us to solve this problem
Please share .out file of the run.
kindly go through the .out file which is attached below
Do you have MATT1 card defined inside the MAT1 card. Is that intended or By mistake? If it is by mistake, then please uncheck MATT1 and run analysis again.
hello Sir,
i did not assign the MATT1, but i assigned the MAT4 and MATT4
MATT4: Defines temperature-dependent material properties for the corresponding MAT4 Bulk Data Entry fields via TABLEMi
Use Table create utility to define Temperature dependent conductivity with TABLEM card.
So if you have defined MATT4 under MAT4 card, call TABLEM card T(K)
