*** ERROR # 387 *** Frequency response load case 1 has all zero loading vectors - check DAREA input data.
i am getting above error while solving FRF analysis for Plate, pls help me to solve this error
Hi @Mahantesh
Looks like the load on model is zero. Make sure you apply loads on your model.
i used unit load on the load collector and assigned DAREA as load type
@Mahantesh
You must be reffering in RLOAD, ryt?
what is the load type in it?
