tied interface and AMS
Simon Križnik
Simon Križnik Altair Community Member
I am trying to run a model with tied interface (Type 2) and AMS. The interface is defined with contact surface as master and nodes on the slave side.
During starter the following warning appears:
WARNING ID :          852
** WARNING SLAVE NODE OF AN INTERFACE TYPE2 & AMS
and during computation:
WARNING INTERFACE          2
 NODE     xxx DE-ACTIVATED FROM INTERFACE
Can this deactivation of slave nodes be avoided when using AMS and type 2 interface? The same model was run successfully using DT/NODA/CST.
  • Simon Križnik
    edited March 2017
    Actually, the deactivation of nodes was due to another interface (type 7) and it was solved by setting the Irem_gap to 1.
    I would still like to know the reason of WARNING ID : 852
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Hi Ivan,
    In AMS for RADIOSS, a node cannot be slave to a Type 2 interface and a Type 7 interface at the same time. A node can therefore be slave, either of type 2 or of type 7. Please correct your modeling in order to solve this observed behavior.
  • Simon Križnik
    edited March 2017
    Hi George,
    Thanks for the tip. The manual also suggests this contact deactivation can be avoided by using Spotflag=25 or 26 (TYPE2 penalty formulation).
    Both methods avoid WARNING ID :  852 ** WARNING SLAVE NODE OF AN INTERFACE TYPE2 & AMS; however some slave nodes of type 7 are still de-activated during simulation, eventhough they are not referenced in type 2. So this de-activation is probably caused by type 7 interface definition (ouput file):
    INTERFACE NUMBER :         2 kontakt
        TYPE.EQ.7   PARALLEL/AUTO IMPACTING
        BOUND. COND. DELETED AFTER IMPACT IN X DIR  0
           SLAVE NODE  (1:YES 0:NO)          Y DIR  0
                                             Z DIR  0
           MASTER NODE (1:YES 0:NO)          Y DIR  0
                                             Z DIR  0
        STIFFNESS FACTOR. . . . . . . . . . . . .   1.000000000000
        STIFFNESS FORMULATION. .  . . . . . . . .    4
     2,3,4,5 : STIFFNESS IS COMPUTED FROM STIFFNESS ON MASTER SIDE
                                     AND STIFFNESS AT SLAVE NODES
        1000 : STIFFNESS IS COMPUTED FROM STIFFNESS ON MASTER SIDE
        MINIMUM STIFFNESS. . . .  . . . . . . . .   0.000000000000
        MAXIMUM STIFFNESS. . . .  . . . . . . . .  1.0000000150475E+30
        FRICTION FACTOR . . . . . . . . . . . . .  0.4000000059605
        VARIABLE GAP FLAG . . . . . . . . . . . .     1
        MINIMUM GAP . . . . . . . . . . . . . . .  0.1000000014901
        MAXIMUM GAP (= 0. <=> NO MAXIMUM GAP) . .  1.0000000150475E+30
        %MESHSIZE TAKEN INTO ACCOUNT FOR  . . . .
        CALCULATION OF MAXIMUM GAP(IGAP = 3). . .   0.000000000000
        FLAGREMNODE : NOT CONSIDER NEIGHBORING  . .
        NODES IN CASE OF ELEMENT SIZE < GAP VALUE       1
        DE-ACTIVATION FLAG IF CONFLITING W/ TYPE2           3
        GAP SCALE FACTOR. . . . . . . . . . . . .   0.000000000000
        START TIME. . . . . . . . . . . . . . . .   0.000000000000
        STOP TIME . . . . . . . . . . . . . . . .  1.0000000150475E+30
        BUCKET FACTOR . . . . . . . . . . . . . .  0.2000000029802
        DE-ACTIVATION OF INITIAL PENETRATIONS . .          1
        MAXIMAL INITIAL PENETRATION FACTOR. . . .   0.000000000000
        CRITICAL DAMPING FACTOR . . . . . . . . .  5.0000000745058E-02
        FRICTION CRITICAL DAMPING FACTOR. . . . .   0.000000000000
        QUADRATIC DAMPING FLAG. . . . . . . . . .     0
        FORMULATION LEVEL . . . . . . . . . . . .     0
        MEAN POSSIBLE NUMBER OF IMPACT/NODE . . .     4
        DELETION FLAG ON FAILURE OF MASTER ELEMENT (1:YES-ALL/2:YES-ANY) :  1000
        FRICTION FORMULATION: INCREMENTAL (STIFFNESS) FORMULATION
        FRICTION FILTERING FLAG. . . . . . . . .          0
        FILTERING FACTOR . . . . . . . . . . . .   1.000000000000
        FRICTION MODEL 0 (Coulomb Law) :
          FRICTION COEFFICIENT . . . . . . . . .  0.4000000059605
          SLAVE SURFACE INPUT BY NODES
          MASTER SURFACE INPUT BY SEGMENTS
  • Altair Forum User
    Altair Forum User
    edited March 2017
    Hi Ivan,
    The possible workaround is setting /INTER/TYPE2 Spotflag to 25 (to switch from kinematic to penalty based tied interface formulation) and it will be affected only to the nodes referenced to TYPE2 interface.
    The /DT/AMS will increase the time step of small elements.  The warning message  NODE xxx DE-ACTIVATED FROM INTERFACE you are getting is due to the kinematic time step of the interface. It is because that the node is penetrating too far into the gap. You can try increasing the Gapmin in your TYPE7 interface which will allow the contact to work sooner and prevent node from penetrating so far.  Or you could try making the interface stiffer, Istf=3 which uses the maximum stiffness of the slave and master.
  • Simon Križnik
    edited March 2017
    Thanks for being helpful as usual, George.
    The interface could also be made stiffer by increasing stiffness scale factor Stfac.
  • Simon Križnik
    edited April 2017
    Increasing the min_gap worked, but during computation the energy error suddenly drops to -99.9% and unrealistic stresses propagate through the structure, when compared to the run with traditional mass scaling (at 1/10 the timestep of AMS).
  • Altair Forum User
    Altair Forum User
    edited April 2017
    Hi Ivan,
    Please ensure that fully integrated elements are used for the run. Also check the hourglass energy in the model.
    Can you please share the engine out file?.
  • Altair Forum User
    Altair Forum User
    edited April 2017
    Hi Ivan,
    Please share the model files through the secure dropbox link.
  • Simon Križnik
    edited April 2017
    I have sent the requested files to dropbox.
    Some parts were modeled with under-integrated elements but hourglass energy is constant throughout.
    I also ran the fully integrated model and the same issue occurs.
  • Simon Križnik
    edited April 2017
    Comparing energy error time history with animation it became apparent there was a modeling issue: shell elements were penetrating into solid edges.
