I am trying to set up imposed displacement between two nodes with moving skew or frame (not sure which should be used). Coordinate system of imposed displacement should be aligned between those two nodes and updated throught simulation. The function curve is defined so the distance between nodes should be gradually reduced. The required behaviour is similar to pretensioned spring but with prescribed displacements throughout simulation.
