I am running Radioss topology optimization to minimize compliance with constrained volume fraction. The plate has all translations constrained on the left and right edges and mass is added. The expectation was that reinforcing ribs would connect supports across left-right direction, which was confirmed with Optistruct. However Radioss optimization produced counterintuitive result with reinforcements running along supports. From the .eslout file it became evident the objective function was minimize maximum compliance; in Optistruct run the objective was minimize compliance.
How to set up Radioss optimization to get results similar to Optistruct? The solver decks are attached bellow if anyone would like to look into.
