Pin hinge and torsion spring
Simon Križnik
Simon Križnik Altair Community Member
edited November 2020 in Community Q&A
what is the procedure to define pin hinge with torsion spring in Radioss with similar functionality as in Motionsolve?
In the file attached bellow I have modeled continuous pin (piano) hinge through type 2 contact with spotflag=4. This works great except there is no option to define small translational compliance (play in the hinge) or joint friction. The other option is to define the hinge through Kjoint2 spring, which requires rigid body on adjacent elements that adds artificial stiffness.
How can torsion spring with rotational stiffness, damping, free angle and preload be added on pin joints?
Welcome!
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Hi Ivan,
    Can you try with TYPE 33 Kjoint?
  • Simon Križnik
    edited June 2018
    thanks for the hint.
    How to model torsion spring (similar to Motionview):
    -Produces a moment between two bodies that is a function of the relative angular displacement and the relative angular velocity between the two bodies.
    -Free Angle specify the angular displacement produced when a torque is applied to the linear torsion spring.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Hi, @Ivan!
    i'm too interesting in hinge connector.
    did you solve it issue?
    how did you model it?
    i'm trying with kjoint, but it doesn't work.
    Have you any idea about it?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Sorry, I missed this question.
    I think type 8 or type 13 should do.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    i see,
    type spring_8 works well, but how to use kjoints? it's reall hard work!
    i have been trying all evening... and i had failled=(
    i want to do just simple hinge with one rotation DOF (revolute joint), but i can't=(
    @Prakash Pagadala could you show how to?=)
  • Simon Križnik
    edited June 2018
    Hi Mrt,
    I did not yet solve the torsion spring in hinge connector.
    The procedure to create kjoint is descibed in https://forum.altairhyperworks.com/index.php?/topic/14759-kinematic-constraints/&tab=comments#comment-39258
    There is also a youtube video about kjoint2:
  • Simon Križnik
    edited June 2018
    Hi Prakash,
    there is rotational stiffness definition for both type 8 and 13 spring. This creates a torsion spring with free angle the same as initial angle. However, I am looking for the rotational spring which is preloaded at the initial time step and tends to open towards free angle, that is different form the initial angle.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Hi @Ivan
    There is an enhancement request already exists for pretension on torsion spring and it should be available in the future version,
    As a workaround, try SPR_BEAM (Type13) with a shifted curve for the say, 1st rotational dof (x-axis rotation)
  • Altair Forum User
    Altair Forum User
    edited June 2018
    If you are looking for something like attached, please let me know,
  • Altair Forum User
    Altair Forum User
    edited June 2018
    Is it kjoint_45?
  • Altair Forum User
    Altair Forum User
    HI,
    It is using spring type 13.
    Files are attached for reference.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    thanks, @Prakash Pagadala.
    i got an answer from support about kjoint_45. it doesn't work correct if you connect 2 RB and use automatic stiffness for rigid DOFs.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    @Mrt
    Could you please share details about what you have done with Kjoint 45?
    Does it has any torsion on it?
  • Altair Forum User
    Altair Forum User
    edited June 2018
    @Prakash Pagadala
    it wasn't about your model.
    i was interesting at kjoin_45, but i couldn't find the answer in the forum how does kjont_45 work. i've been writing  to support for 2 weeks, but they sent me presentations that consist the information from user_guid and tutorial.
    But Hueseyin Cakir had checked my model then connected to development team. it willbe fixed in the next radioss release.
  • Altair Forum User
    Altair Forum User
    Hueseyin has done presentation about it.
  • Altair Forum User
    Altair Forum User
    edited June 2018
    @Mrt
    OK, let me track that.
Welcome!
Welcome!
