I am working on Altair Inspire (Version 2023.1). I am working on to generate a Lattice structure from a well defined topologically optimized CAD. In the Optimize option, I am not seeing Lattice as Type (Please Find Attached Image).
How can I get it?
Hi Dhee,
The image you have shared looks to be from a previous version and was unfortunately not updated in our manual. Only the Topology, Topography, Gauge, and PolyNURBS optimization options are detailed in the help documentation:
https://2024.help.altair.com/2024/inspire/en_us/topics/inspire/structure/optimization_types.htm
However, the lattice creation options can be found under the Implicit Modeling ribbon and give you options to create surface, planar, strut, or stochastic lattice structures.
Hope this helps!
Adam Reid
Hi Dhee, The image you have shared looks to be from a previous version and was unfortunately not updated in our manual. Only the Topology, Topography, Gauge, and PolyNURBS optimization options are detailed in the help documentation: https://2024.help.altair.com/2024/inspire/en_us/topics/inspire/structure/optimization_types.htm However, the lattice creation options can be found under the Implicit Modeling ribbon and give you options to create surface, planar, strut, or stochastic lattice structures. Hope this helps! Adam Reid
Thanks Adam for the guidance.
