Please, what is the purpose of the "surface to surface" and "clearance" parameters ? When should one or another be enabled?
Hi Rita,
these are more related to the solver that you are using, in this case OptiStruct.
Clearance allows the user to pre-define the clearance/gap in a contact independently of the actual node distance. This can be used when the mesh is not so good, and you want to define a pre-defined gap (even negative for interference/press-fit).
Surface to Surface is related to the discretization of the contact pairs. Is could be Node to Surface, a little bit simpler, where each slave node finds a master surface to create the contact. Surface to Surface distributes better the contact pairings creating a connection between both surfaces.
For more details take a look at OptiStruct help documentation:
https://community.altair.com/community?id=community_blog&sys_id=538764ab1b3790d4a5f742eddc4bcba4
Hi Rita, these are more related to the solver that you are using, in this case OptiStruct. Clearance allows the user to pre-define the clearance/gap in a contact independently of the actual node distance. This can be used when the mesh is not so good, and you want to define a pre-defined gap (even negative for interference/press-fit). Surface to Surface is related to the discretization of the contact pairs. Is could be Node to Surface, a little bit simpler, where each slave node finds a master surface to create the contact. Surface to Surface distributes better the contact pairings creating a connection between both surfaces. For more details take a look at OptiStruct help documentation: https://community.altair.com/community?id=community_blog&sys_id=538764ab1b3790d4a5f742eddc4bcba4
Hi Adriano, thank you so much for your help.
