I am attempting to Geometry > Create > Surface > Square but after defining the normal vector, base node, and size (Y-axis, (0,0,0), 0.010), I only end up creating what appears to be a line, though it is treated as a surface (if I try Geometry > Delete > Surface, I am able to select it as if it were a surface). The bright green line (in the image, shown below) is what appears with just a "wireframe" view and the grey dashed grid lines appear with a "wireframe geometry and surface lines" view. I do not understand why it is showing as simply a line (generally) - I have tried changing all sorts of view/display types and cannot ever see a "solid" square surface. It's worked many times before, so I am confused about what is going on here. Other than HyperMesh allowing me to select it as if it were a surface, I cannot actually 2D mesh it as if it were a surface. I have tried completing deleting the component, creating a new one, and creating the square surface again but still run into this error. I have also tried exiting HyperMesh and re-opening the file, but still, the issue persists.
Has anyone run into this before and perhaps knows of a fix?
Thank you in advance for any advice you may be able to provide.
(If it matters, the User Profile is for Radioss 2021)
.PNG)
