How to determine strain history of part?
Autumn
Autumn Altair Community Member
edited August 2021 in Community Q&A
I am trying to determine the strain history of a part - either maximum strain or maximum plastic strain over the run time - but can't seem to figure out how to go about plotting such a thing. I understand it is possible to contour plot the plastic strain of 3D elements in HyperView, and that I could then plot this vs time for a specific element(s), but is there any way to just plot the maximum of all elements (I'm not really concerned with which element this maximum occurs if this makes it easier)?
Is it possible to do in either HyperView/HyperGraph or HyperStudy? Or perhaps using Compose is the best way (I am not very familiar with this program yet)?
(I am looking specifically at 3D elements and am using Radioss).
Please let me know if you require any clarification.
Thank you in advance for any tips and help you can provide.
Best Answer
  • Adriano_Koga
    Adriano_Koga
    edited June 2021 Answer ✓
    hi,
    you can get this easily in HV+HG.
    Plot your results for strain in HV.
    Activate the 'measure' panel, and activate the 'dynamic measure' and choosing only 'max' value (turn of any other).
    Then go to 'Create curves' in the measure panel, and create a new curve with 'live link' enable.
    This will create a new HG window with your maixumum over time.
  • Michele Macchioni
    Michele Macchioni
    edited June 2021
    What about using BCElemToPart and which will aggregate all values >> you will ask for max
    once the data is there as new results you can use standard measure for each part and plot the curve in HG.
  • Adriano_Koga
    Adriano_Koga
    hi,
  • Michele Macchioni
    Michele Macchioni
    edited May 2021
    hi,
    Adriano,
    FYI: The approach of dynamic legend is valid for global maxima.
    Leveraging part aggregation would allow as well the screening for each part.
    That being said, the approach thru measure is valid at the end for both methods.
    Thanks
    Michele
  • Adriano_Koga
    Adriano_Koga
    edited May 2021
    Adriano,
    Thanks
    Michele
    good point, Michele. :)
    Using result math is a really nice approach.
    for the dynamic measure to work for a particular part only, it is necessary to select and contour only this particular part.
  • Autumn
    edited June 2021
    Thank you both for these suggestions!
    I ended up contouring only the one part of interest in HV and utilized the dynamic measure to create the HG curve.
  • Michael Herve_21439
    Michael Herve_21439
    edited July 2021
    Hello Automn,
    in our latest 2021.1 version, HyperStudy allows a new model HyperView.
    This model allows to create some metrics with the HotSpot Finder in HyperWorks View (HyperView with the new interface). The results can be stress, strain,... and you can control the selection of elements.
    Eg you can remove from element selection the first raw of elements connected to rigid elements when post-processing stress results.
    You can set up as much metrics as you want (one per Window), save your HotSpot Finder settings for each window wit a relevant name, then save your session file.
    Then, once back in HyperStudy, define a HyperView model and call the mvw file. Also, make sure to link the output file from your first model to the HyperView model.
    We'll post soon an article in the Knowledge Base an article regarding this new model, with extra details. I'll post the link t this article in this page when available.
    Best Regards,
    Michael
  • Autumn
    edited July 2021
    Hello Automn,
    Best Regards,
    Michael
    This information is good to know! I look forward to the article in the Knowledge Base.
    Thank you!
    Michael Herve_21439
    edited August 2021
    Thank you!
    Hello Autumn,
    here's the link to the freshly published article regarding HyperView model in HyperStudy :)
    https://community.altair.com/community?id=kb_article&sys_kb_id=249161071bb970d0c4dfdbd9dc4bcb56
    Best Regards,
    Michael
