I have a sandwich assembly. One of these layers is the spring. This sandwich structure is fastened together with bolts. The simplified form is below. During the assembly phase, the spring is mounted under pressure.
How do I add this spring to the model? But I want to add it in 3D, not as a spring element.
Thank you.
Best Regards,
Ovunc
