Hello ,
When I want to solve the analysis that I solved in version 2019 before, I get the following error in version 2020.
*** ERROR # 6537 ***
Inertia relief for nonlinear analysis with non-freeze contact is not allowed.
PARAM,IR4NLCON,YES can be set with caution to bypass the restriction.
But I could not find IR4NLCON under the PARAM.
How do I solve this problem? Can you help me?
Thanks.
