How to coupled radioss and motionsolve solver?
Is it possible?
Thank you for help .
Hi, There is no direct coupling. Regards, Dhanasharee Jadhav
Firstly, thank you for information @Dhanasharee Jadhav
I am working on modeling the sloshing motion of water in a tank carried on the vehicle.
I want to modeling the sloshing motion of water with SPH in Radioss. Then I will add the effects caused by the sloshing to the vehicle model in motionsolve.
In short, I want to transfer data between radioss and motionsolve. You said earlier that there is not direct couple between radioss and motionsolve.
What would you recommend so that I can do what I think?
Thank you.
I am working on sloshing motion of water in a tank carried on the vehicle.
The coupling that you mentioned could be done between Motion solve and Acusolve. being Acusolve the CFD solver.
Please refer to the tutorial in the link below.
https://2020.help.altair.com/2020/hwsolvers/ms/topics/solvers/ms/co_simulation_acusolve_intro_r.htm#reference_rb5_pcs_s3b
Regards
Thank you @Rogerio Nakano,
I know the co-simulation you are talking about.
But I want to model the liquid with SPH. And, I am modelling SPH in Radioss.
So how can be transfered data indirectly, if not directly, between Radioss and Motionsolve?
What do you suggest?
Does anyone have any ideas or advice on this matter? I request your help.
