I am working on sloshing motion of water in a tank carried on the vehicle.
I want to modeling the sloshing motion of water with SPH in Radioss. Then I will add the effects caused by the sloshing to the vehicle model in motionsolve.
In short, I want to transfer data between radioss and motionsolve. But I found out that there is no direct coupling between radioss and motionsolve. Now I am planning to do this step by step. So I am thinking of getting results in one solver and transferring it manually to another.
Can you tell me any alternative method to the solution I mentioned, other than FSI?
Thank you.
