Hello everyone,
I'm playing with the PBLAST load in RADIOSS, but the model displays the warning "/PLOAD/PBLAST, R/W**(1/3) > 400.0 mus/g**(1/3)", then lists the affected segment nodes. The solver does not throw an error and wrote the first animation file, but nothing further seems to happen apart from listing every single affected segment node. What exactly is this warning telling me? I defined a 1kg TNT charge near a shell mesh, and the affected surfaces is defined via a surface segment. Searching the documentation did not yield any results, as there seems to be very little about blast loads in there.
