Missing "NORMAL TERMINATION" in output file
User: "Autumn"
Altair Community Member
Updated by Autumn
I have created a model in HM and am attempting to run it through Radioss, but receive the error:
in a pop-up within the first minute or so after running it.
I have checked that each component has a property and material, and double-checked that there appears to be no errors with the control cards, but am still receiving this error. I am quite confused as I have run this file successfully before, and had only removed a component and some materials that were empty / unreferenced. It also returns zero warnings and zero errors, so I don't really know where to begin looking for a solution.
Is anyone familiar with this error and how to fix / modify the model in order to correct it?
Thank you in advance for any help.
(I have attached the two .rad files for reference, as well as the .out file generated, in a .zip file to stay below the maximum file size upload limit.)
Edit: I have also attempted to run the original model file without any further modification (which has previously run successfully) and am also receiving this error.
