Can NLSTAT with LGDISP=1 work out spring deformation problem?
hyperlove
hyperlove Altair Community Member
I saw a previous thread in this forum asking for help about an off-center 20-layer spring deformation problem.
The location of that thread is here:
I wanted to continue that question, but with a spring meshed with solid elements (Not shell elements).
---1st Q---:
How to define self contact of a spring meshed with solid elements (because every two adjacent layers will be in contact during spring compression)?
---2nd Q---:
Can OptiStruct NLSTAT with LGDISP=1 work out such highly geometric non-linear solid-meshed spring deformation problem?
For example, the analysis in that previous thread was trying to solve an 120-degree rotational displacement loadcase, but was ended with weird final deformation.
Thank you.
  • Altair Forum User
    Altair Forum User
    edited February 2018
    Starting from 2017.2 one can model self-contact in OptiStruct.   To activate self-contact, the master surface ID needs to be kept blank or same with slave surface ID.
    This could be due to element distortion, other material properties.
Welcome!
Welcome!
