I am attempting to simulate the impact between a plate and a block at different speeds but am struggling with understanding parameters/load steps/etc. So far, I have created the proper file in HyperMesh and successfully simulated impact (with results), but I am curious about how I should approach simulating a variety of impact velocities (i.e. the plate at a variety of initial velocities just prior to impact with the block) without simply simulating it at one initial velocity, and then editing the file in HyperMesh to simulate it with another initial velocity before finally attempting to combine the data to analyze how the results change (as this is quite a time consuming task and I would benefit from being able to set up multiple scenarios and let the computer run and process overnight). Is there a way to make use of parameters or other features in HyperMesh (for Radioss) to simulate multiple impact scenarios at different initial velocities all in one go?
Please let me know if you require any clarification.
