Is there an option in simlab to remove part numbers from the CAD?
Hi Bhagat,
There are some options available for it. In version 2021 (the one set for your question), you may use:
1. Defeature Logo and Details Mesh Control: Select the part numbers faces.
or
2. Mesh the CAD as it is, then go to Geometry > Features > Details (Logo): Once again, select the faces you want to suppress.
In case you are using version 2021.2 or higher, you will also have the option to use the Details tool on the CAD itself (exclusive to parasolid CAD format).
