I was doing finite element modelling and later will do analysis of a bolted joint most probably in Optistruct. So as you know there will be friction between the plates and bolts and accordingly i have to assign friction. I have like the value of co-efficient of friction for like between plates and bolt etc. with me. So can i input it during setting up contacts between the interfaces?
