I thought Altair had introduced a feature to generate lines (for 1D meshing) from solid tubes, rods, beams CAD geometry. I can't find that command in 2021.1. Is it removed?
Secondly, I hope this is a bug and not a feature. In previous releases (2020x), HW used to remember values entered previously (for example in toggle edge tolerance value in quick geometry edit panel) and would retain the same value when the panel is opened again. But in 2021.1, I noticed that values revert to default. Not a huge deal breaker...same thing happened in settings as well. I had clicked on "Smooth" display option but it would revert to flat and I had to redo setting to Smooth a few times and up on reopen, it had retained that particular setting.
There were a few outstanding bugs in v2020x (CBUSH orientation was not being shown correctly using Orientation Review tool)...not sure if they are resolved in 2021x...hopefully they will be soon. One feature I would like to request is ability to change line thickness. If I have a bunch of lines drawn, it would be easier on the eyes if we could change thickness of the same (color can be controlled via putting them in a different collector)...
I will add on to this thread as I find more...
