Need help in Composite Post-processing Operations
Burner2k
Burner2k Altair Community Member
Having issue with doing post-processing op of a composite part in HV.
Created this component in HM. The zero degrees plies (or Material Orientation direction is along +Z axis). The set up is pretty simple. Fixed on one side and an axial load on the other side. The solver I used is MSC Nastran and PCOMPG cards were used to define laminate.
<?xml version="1.0" encoding="UTF-8"?>01.thumb.PNG.31b99fb0db42108c015690a7b6bba398.PNG
The cross-section of the component showing the laminate.
Selected 'Composite' option during the initial setup where I point out to model & results file.
The option Global System (projection: None) is greyed out. Was under the impression that I could select 'Projection Active' (or something similar) and use the Global Z direction to tell HV to transform Ply 1 XX results. This is how I usually post-process in Patran.
Next I created a user defined coord system and had HV point it out to transform (System id =1). But still I am not getting any output. What am I doing wrong?
<?xml version="1.0" encoding="UTF-8"?>02.thumb.PNG.8c1a4ec70ed7ef5d1556974a409c08f0.PNG
  • Burner2k
    edited January 2018
    I also want to add that I am able to obtain any deformation pattern in Hyperview. Although HV shows the Contour values of Deformation in the model, somehow it is not showing the deformed shape. Supposed to have a slight bend as shown below in MSC Patran.
    <?xml version="1.0" encoding="UTF-8"?>03.thumb.PNG.c60ffde08a309d3027cb2b3305f3cc24.PNG
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    Could you please share the result file?
  • Burner2k
    edited November 2020
    I have attached a copy of the both bdf file & op2. Hopefully you'll have better luck than I did.
    Thx,...
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    Can you check if you see any results in Analysis system?
  • Burner2k
    edited January 2018
    Hi Prakash,
    Yes, I am getting results in Analysis System.
    <?xml version="1.0" encoding="UTF-8"?>01.thumb.PNG.d69443476936e8419d7e2e4dab438ebf.PNG
    What does this DEFORM function do in Hypermesh? I was not able to find any references in Hypermesh Documentation. If I check the Deform check box, I am supposed to select a Load Collector. Should this be checked to obtain Deformation shape?
    <?xml version="1.0" encoding="UTF-8"?>02.thumb.PNG.c307b4dcd501a6d536e8aaad89dd3069.PNG
    Also, in Hyperview I created a Projection Rule where the Global Primary Axis points to or transformed to Z direction as shown below:
    Still no joy in getting Ply results displayed
    <?xml version="1.0" encoding="UTF-8"?>04.thumb.PNG.135cf0b39c40465e0f318dd03bf65093.PNG
  • Burner2k
    edited January 2018
    Hi Prakash,
    Are you having similar issues I am having at my end? Hoping for suggestions on how to resolve the above.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    Deform defines axial deformation for 1D elements.
    I will check if I can reproduce the same at my end and I will share my findings.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    I see that projection rule works for element stress and not for composite stress.
    I am going to check with experts on this.
  • Burner2k
    Did not want to start another thread but I dunno why I am not able to plot deformation shape in Hyperview. I even made a very simple Test case of a 2D Isotropic plate subjected to axial load. But I just not able to obtain the deformation shape on HV.
    I am attaching the bdf & op2 files. I want to get some resolution on this soon. Please help.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    Do you see displacement and stress contour?
    If yes, change the Deformation shape scale factor.
  • Burner2k
    edited January 2018
    Hi Prakash,
    I was just about to post that I think HV was showing the deformed shape but I had to adjust the scale of it. I will investigate the same on other models including the composite one and report back.
    In the mean time, I would appreciate if you could do give a glance on why Stress Global Projection for individual plies are not working.
    Thanks for your reply. Appreciate the continued support on this forum.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    @Burner2k
    I have already in touch with Devs. I am expecting some feedback today/ tomorrow
  • Burner2k
    edited January 2018
    ^^Cool man. Thanks for the update...
  • Burner2k
    edited January 2018
    Hi Prakash,
    Any updates from developers about the composite transformation issue?
  • Altair Forum User
    Altair Forum User
    edited January 2018
    No, not yet.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    So here is an update:
    Try after loading both model file and .op2 file in HyperView with Advanced Option
  • Burner2k
    edited January 2018
    ^^What exactly does the above mean? I do load both files IIRC. I point out to bdf file & op2 files and then to 'Composite' when I first start HV. Unless that has to be repeated else where...I would say that I am doing that already. I am currently away from computer. Will try to post pictures later.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    HI,
    Yes I can see that from your first image.
    Please use Advanced instead of composite Result Math template.
  • Burner2k
    edited January 2018
    Hi Prakash,
    I did a quick check per your suggestion using Advanced template instead of Composite and it seems to work. I forgot to do a check on transformation of results for a User Defined Coord Sys, but I'll take it that works as well while using Advanced template.
    Thanks for your support and resolution. Appreciate it a lot.
  • Altair Forum User
    Altair Forum User
    edited January 2018
    Hi @Burner2k
    Please share your finding regarding the same.
    If you feel something is NOT correct, please do let us know... :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
