🎉Community Raffle - Win $25
Join and Win
Editing Load Application Region in Hypermesh
User: "Burner2k"
Altair Community Member
Updated by Burner2k
I thought I had posted this question on the forum, but I am not able to find the thread. Apologies if the posting is redundant.
I had applied forces on nodes using 'On Free Edge' option. Now I need to edit the load application region.
As shown in the attachments below, the original load application region involves all the curves of I-beam C/S. I want to apply the load only on the web curve of the I-Beam. I tried changing the same using Analysis->Forces->Update and choose the displayed load/force.
The curve selector is being highlighted. However, I am not able to select any curves from the screen and when I click on the curve, I am taken to a page which contains blank screen.
Any suggestions on how I can edit load application region in Hypermesh?
Thx
1 - 7 of 71
    User: "Udhayakumar Ramasamy"
    Updated by Udhayakumar Ramasamy
    The curve mentioned in this Force tab is Load curve (Load vs Time).
    If you want to delete the loads you can use F2 --> loads and select nodal loads which you want to delete.
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    If curve is not available that means you have not assigned any curve to load.You would have applied load with constant vector.You can update load direction & dof easily.
    User: "Burner2k"
    OP
    Updated by Burner2k
    Thx folks for the responses. I want to update the load application region without having to delete an existing load and create a new one. I will check out the options you folks have mentioned above in a while but going through the responses, it seems like currently there is no way to edit/update load application region in Hypermesh?
    Refer attached video for updating load with constant vector.
    User: "Burner2k"
    OP
    Updated by Burner2k
    Rahul,
    Thanks a ton for the video. The application region can be edited in Hypermesh, but only one 'load' at a time. I was selecting the entire displayed lot.
    Last question, is there any utility or function to check the sum of external forces & moments in Hypermesh? Just to make sure that total load is correct before submitting for analysis?
    You can update all load at a time. In video i covered only one load but it work for all load in one go.
    For overall check use model checker.
    User: "tinh"
    Updated by tinh
    Rahul,
    There is utility to check sum of external forces & moments,
    Please enter panel post>summary> click 'load', browse to ....\altair\14.0\templates\summary\optistruct
    select template file 'loads'
    => click 'summary'
