pressfit analysis with static load subcase
In optistruct, I want to simulate a load by taking account of the interference fit at a sleeve location.
How to run this into two seperate subcase?
I would like to use static case for better solving time is this ok, or I need to use NLSTAT for both cases
can you please help me with an example solver file.
Thanks,
Sid
Hello Robinson,
Thanks for the answer so far.
Sorry for late reply, I was preparing the model these days.
I checked your model, I see there is physical geometrical interference of 20mm, so below is the PCONT is used in your file.
PCONT 2 0.0 -20.0 YES
But, In my model, I do not to have any physical interferece between geometries, I mean the geometries are just touching each other without penetration.
In my case, how can I input the interference fit value ?
Looking forward for your answer.
Kind regards,
Sid
Hi Sid,
Please see attached a small deck showing how to do this.
I'm using the model in this example from here: link
I added a new subcase continuing from the interference fit subcase.
In this model, a negative clearance is being used to resolve penetration (which is often used to help with convergence). In subcase 2 it is necessary to use CNTNLSUB to continue from the previous subcase, which means that both subcases must be of the same type: NLSTAT SMDISP or LGDISP.
Hope it helps you. Consider marking this answer as correct if it solves your problem, so other people may be helped too.
Thank you very much
