Hello
I need to perform a pre-stress modal solution using inertia relief. I am looking for a sample deck where static solution with inertia relief is done first with gravity loading and then followed by modal solution as the next step. Both inertia relief and the modal solution is performed in one solution run. The model includes linear contacts between parts. can you help with a sample deck?? Would be great if you do the needful.
