Does anybody know if it is possible to enforce a sweep (chirp) excitation for a nonlinear transient analysis?
Thanks,Yuri
Hi sir,Thank you for the answer. Yes, this seems to be a quite time consuming procedure.Isn't there a way to express a forcing term through a table? (One in which functions can be expressed).I know there is something similar in other softwares (eg MARC).
Hi @Yuri S.
The only way i'm aware of is to define these as tables/curves, explicitly defined.
But you can easily create then into Compose or Excel, generate a CSV/TXT file an import to HM as a table (Utiliy>>Table Create).
In HW2021, just create a curve, and copy and paste from Excel to your curve editor.
as far as I know, you would need to apply this as an explicit curve (TABLED1) entity, and associate it to your TLOAD1 card.
BUT, for a NL Transient card this would probably be very time consuming.
Hi @Yuri S. The only way i'm aware of is to define these as tables/curves, explicitly defined. But you can easily create then into Compose or Excel, generate a CSV/TXT file an import to HM as a table (Utiliy>>Table Create). In HW2021, just create a curve, and copy and paste from Excel to your curve editor.
I missed out this valuable piece of information!
Thank you very much.Yuri
