It seams impossible to export nastran or optistruct files with HMMOVE instead of HMCOMP. I need this format to process the mesh after and don't lose the assemblies when I postprocess or reimport the model.
Do you have an other export file which wock with 2021 versions (older versions don't work with the new one) or an external script to switch from HMCOMP to HMMOVE ?
Thank you,
Norbert
