I have created a Type5 contact between spring elements as slave which is impacted by a component as master(shell elements). since my requirement was to make the spring elements fail, i used failure criteria for these elements. The elements failure is accomplished well as soon as the failure limit is reached, however I could see the spring elements penetrated into the surface, when the elements are impacted. I think my contact did not work well. Could anyone please suggest if the contact type is right one?
