Altair RISE
Nominate Yourself Now!
Error while applying concentrated load
User: "Ushay"
Altair Community Member
Updated by Ushay
I am testing quasi static tensile testing with radioss explicit. I am trying with imposed velocity, imposed disp as well as with concentrated load. Imp vel and imp disp type gave good results, however the run with the conc. load is failing at the initial stage. I created a rigidbody and gave all the nodes in it over which forceacts. I picked the master node of the rbody and applied load.
The error ID I get is 207, which says max. energy error reached.
This happens at the contact interface, which I defined for all the components with type7, a global contact.
Any suggestions be helpful. Thanks!
1 - 3 of 31
    User: "Altair Forum User"
    Updated by Altair Forum User
    Hi Ushay,
    Can you please share the starter out (_0000.out) and engine out (_0001.out) files.
    User: "Ushay"
    OP
    Updated by Ushay
    Hi George,
    unfortunately I cannot share the file. Could you please give any suggestion, with out the file?
    Hi Ushay,
    From the out file we can check for any warnings/errors listed and from the engine out we need  to check the error trapped during the run. No model info will be available from the out files, and so please share thereby we can suggest some workarounds.
