I have the following questions running over my mind. I would appreciate if any one can brief out their knowledge
1. My model has a foam over which there is a firm seat cover. Since the foam is in compression because the seat cover holds it tight, I would like to define a post-tension to the foam. I used - /MAT/LAW70 for this, and I could not find this in ver 12. Can anyone suggest will I be able to do this?
2. A more similar question related to Pre-tension, but this time it is for a spring element. I use PROP/TYPE13 for these elements so that I could give rupture criteria. I have seen pre tension option in TYPE/32, but unfortunately I can't use this type. Can anyone help me out is there a way to define with existing type?
3. Might be funny, but sorry. I have been running simulation since a couple of months and all seem well till today. Strangely the runs I did today have generated a couple of .rst files, though I used the same engine file I did for previous runs. Is it a sign of any modeling error?
I have defined the same interval for all of my runs
/RFILE
200000 0 0
I appreciate for any of your suggestions. Thanks in advance
