Hi All,
Please see the attached image. I have assigned the property for spring elements in HyperCrash and had a look in Hypermesh. The card image is not supported. Thanks for your support
This keyword is supported in HyperMesh yet, and probably in the next release it maybe supported.
But for RADIOSS solver this property is supported. You can create or modify in HyperCrash or manually and can run the simulation.
