I am trying to do an analysis on a enamelled sheet metal part, it is bimaterial. As initial condition, temperature is 350 celcius degrees and as final condition, temperature is 25 celcius degrees. So, I applied a temperature load.
I used MATT1 and entered temperature dependent material properties in TABLEM1 format. I used PCOMP card to model the structure as composite. Materials (Steel and Enamel) are taken as isotropic materials so there is no ply orientation.
When I start the analysis with Optistruct, the programme gives the following error message:
ERROR 14: Missing property # 2 referenced by CQUAD4 # 1
What can I do to solve this problem?
Thanks in advance.
Mert
