I have created a tcl script that is supposed to perform following activities:
- Open ppt object
- Add new slide
- Paste animation (.avi) files.
- Save the file
- Close the ppt
Everything works fine, but at the end ppt does not close. Here is the code that I have written. Is there anything that I am missing out?
set job_folder 'C:\\Users\\xcxc\\Desktop\\test_ui\\test' set num_of_modes 15 #get the directory# set dirname [file dirname [info script]] set template_dirname '$dirname/Report_Template.pptx' #handle the files# file copy -force '$dirname/Report_Template.pptx' '$job_folder/Report/Report.pptx' #modify the PPts# package require twapi set ppt [::twapi::comobj PowerPoint.Application] $ppt DisplayAlerts [expr 0] set presents [$ppt Presentations] $presents Open '$job_folder/Report/Report.pptx'; #Open the Presnetation set active_presentation [$ppt ActivePresentation]; #get the cureently active presentaatin set slides [$active_presentation Slides]; #gte the slide list set slide_1 [$slides Item 1]; #get control on slide index 1 set object_list {} set mode_counter 1 while {$mode_counter <= $num_of_modes} { set slide_num [expr {$mode_counter + 1}] set slide_$slide_num [$slides Add $slide_num 12]; #add one more slide into the presentation set slide_$slide_num\_shapes [[set slide_$slide_num] Shapes] set slide_$slide_num\_video_1 [[set slide_$slide_num\_shapes] AddMediaObject2 [file nativename '$job_folder/Report/Mode_$mode_counter\_Iso_Front.avi'] -1 -1 20 100 650 300] set slide_$slide_num\_video_2 [[set slide_$slide_num\_shapes] AddMediaObject2 [file nativename '$job_folder/Modal_Analysis/Report/Mode_$mode_counter\_Iso_Back.avi'] -1 -1 500 100 650 300] lappend object_list 'slide_$slide_num' lappend object_list 'slide_$slide_num\_shapes' lappend object_list 'slide_$slide_num\_video_1' lappend object_list 'slide_$slide_num\_video_2' incr mode_counter 1 } $active_presentation Save foreach object $object_list { puts $object [set $object] -destroy } $slides -destroy $active_presentation -destroy $ppt Quit $ppt -destroy
