I tried removing the element set (Spring element) from the model using MODCHG , while doing so it errors out
*** ERROR # 4921 ***
The element being removed/reactivated can only be solid element.
Removal/reactivation of element #152 (referenced by SET #1)
with MODCHG #3 is not supported.
If i try removing shell/solid element using MODCHG, its working fine
Is it Possible to remove 1D/ spring element set ?
