NLPARM
I am trying a nonlinear DTRAN load case in OptiStruct
Can you please share an example/Tutorial that effectively uses all the NLPARM parameters ?
I am confused with the NLPARM parameters and also with the NLOUT parameters , really finding hard to control the animation output time step.
Please do share me if any links / tutorials
Karthik,
You need to try changing the NINT (number of intervals, trial and error). Right now there is no option to output results at a particular time step.
0 -
Hi Prakash,
what about the NLPARMX option in NLPARM. Is it only for Static Analysis ?
can DTA(Output time step for animation files) help?
I am trying out NLPARMX, but no impact on animation results
0 -
NLPARMX is for NLGEOM implicit. Are you using NLGEOM analysis type?
Instead you can try DT and TTERM on NLPARM. Check if this gives any good results.
0 -
Thank you Prakash
I am doing nonlinear Direct Transient
Is it possible to continue the run in subcase2 ? including the effect of case 1
0 -
karthik,
Yes, please use CNTNLSUB
0 -
Karthik,
To avoid confusion, you can create CNTNLSUB within subcase.
Edit the 2nd subcase and find the CNTNLSUB and refer the fist subcase in the same.
0 -
sorry for simple question, I coudnt find CNTNLSUB within subcase and how to link
0 -
Karthik,
It should be available in Nonlinear with DTRANS subcase. Click edit and should be able to see it.
0 -
Hi karthik,
Looks like you are using Direct transient analysis type and not Nonlinear Direct transient analysis. This is added in 2017.
0 -
Hi Rahul Rajan and Prakash,
Thank you for the support
