Rigid body
I am doing modal analysis, tried to make one of the component rigid by giving a high Young's modulus value. during computation
A fatal error has occurred
*** ERROR # 277 ***
Jacobi method failed.
Max. off-diagonal term in matrix = 2.74951e+295.
Please help me in resolving... How to make the part rigid instead of using rb2 ?
Hi Karthik,
Try with RBODY (RIgid body) and check if this helps.
0 -
Hi Prakash,
How to make it. where do we find RBODY card?
0 -
hi Karthik,
You can right click on Model Browser>> Create>> Rigid body. Make sure you go through the Rbody card on OptiStruct help before you create as it gives a fair idea on what is required for Rbody.
0 -
I think rbody is not available for optistruct solver. You can see it in radioss . Might have come up in 17 version.
0 -
Thank you Gopal and Prakash,
I tried giving a high Young's modulus value which results in computation error
*** ERROR # 277 ***
Max. off-diagonal term in matrix = 2.74951e+295.0 -
The methodology seems to be correct for making part rigid i.e provide a high value of E. Are we sure that this error is due to this? I mean is the model running properly if you use rbe2 for making rigid?
Can you share the screenshot for material properties also?
Jacobi method solves equation using a iterative method where it makes the off-diagonal term zero. Thus this might be a convergence issue also.
0 -
Hi Gopal and Karthik,
There is a RBODY in OptiStruct starting from 2017. Please see the image.
But I think the problem is coming from the flexbody frequencies as the offset is tool large.
Can you try to reduce the mass of the rigid body and check if there is any improvement.
0 -
Thank you,
The model running properly if i assign a realistic value for E and also with rb2.
All i need is Rbody card for the component which i coudn't find in Hm V14.
0 -
Karthik,
Can you share the modulus value used?
I dont know if there is a better way to define a rigid body.
0 -
Hi Prakash,
I used 9e150 Mpa
0 -
Hi karthik,
Can you try with something like 9E20/25?0
