Hi All,
I am trying to get mvw file output from transient and Frequency response problems. How can I do so.
I have used GLOBAL_OUTPUT_REQUESTS, OUTPUT>>HGTRANS & HGFREQ
But still don't see any .mvw files created.
Hi @Karthic
At the end of every analysis, a .mvw file will be written to the working directory,
Are you trying to output response vs time/frequency?
Hi @Prakash Pagadala,
Thankyou for the help, I got the .mvw file.
I couldn't open it in the data file: tab directly, but using File > Open > Sessions worked.
I ran a test model and it works fine,
Are you using HGFREQ, FL for FRF analysis?
Can you try with HGFREQ, ALL, instead?
Can you share the file which you are working on?
Thankyou for the help, I got the .mvw file and working fine
@Karthic
Thank you for the update.
