Failure models
Hi All,
Is there any failure models available in Optistruct for implicit nonlinear analysis?
I need to remove the elements once uts is reached / strain value reached ?
Thank you
N.K
I am looking for plastic material, for now I am using the MAT1 with MATS1 (table data).
I am facing the non convergence error due to heavy element distortion. So I would like to remove the elements failed in the model.
Thankyou
0 -
Hi @Karthic
Have you gone through MATF card?
In MATF you can use DUCTILE failure with a limit on stress.
0 -
Thank you @Prakash Pagadala,
What should I select for criteria field in the MATF card?
0 -
If I am using STRN, should I specify the Material stress limits Vi and Parameters for failure envelope.
where to mention the Strain limit ? /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
Thankyou
0 -
Thank you for the efforts.
So for now element deletion due to material failure is not possible with Optistruct ?
0 -
Yes, you may have to use RADIOSS,
0 -
Thank you Prakash. Let me try in Radioss
