I need to find the reaction forces for transient analysis.
I tried using SPCFORCE, GPFORCE.... But i don't find the results in H3D nor out file? Is it possible to find the reaction force
Hi karthic,
Can you try with .op2 format?
Hi Prakash
How can i view the results of .op2 file?
Thanks for support.
Karthic,
You can open in HV or HG to plot the reaction forces.
Prakash,
By doing so i am getting error message stating
28 Error: The supplied OP2 File does not contain any results/supported Result Blocks
29 Error: Failed to attach results.
