I am studying FEA using HyperMesh and Optistruct.
Now I'm trying to analyze the stress of cylindrical vessel with support plate.
In accordance with the tutorials, I've created the mesh and load collector, but I don't know how to create constraints to support plate.
In this case, constraints are attached only to the support plate. it cannot translate to vessel's axial direction and its radial direction , but can translate to its tangent direction (the distance between the center of vessel and plate does not change, please refer to the attached picture.)
I know axial constraint can be achieved by adding SPC to all elements with checking dof of axial direction.
But I don't know how to fix the plate only its radial direction.
Thank you,
