Dear Sirs,
I'm trying to solve the pipe stress analysis according to the example ASME B 31.3 appendix S Fig.301.1, shown in below URL.
LINK: ASME B31.3 pipe analysis example (page 21 & 22)
I made the most of the pipe model except the pipe support at the node No.20.
No.20 support is the constraint of vertical (Y-axis) movement of the pipe, so firstly I made the SPC with dof of '13456' aroud the pipe, but the analysis result showed unexpected movement.
My SPC is fixing the vertical movement of 'node on pipe surface', but I have to made is fixing vertical movement of all pipe elements passing through at the node 20. Therefore I have to made some constraint at the node No. 20 in global coordinates, not at the node on the pipe surface.
Please refer to the attached .hm model. I assume this is non-linear analysis, but I have'nt done such analysis so I dont know what to do.
I would appreciate any advice.
Thank you in advance.
