hi,
I m doing NLSTAT pretensioned bolt sequencing analysis in hypermesh and using optistruct solver (version 13). I know to use sequencing using CNTNLSB card.
I m pretensioning bolts in sequence on cylinder head gasketed joint using pretension manager by creating contact surface in shank portion of bolt and applying PTFORCE on it. Now after round one of applying PTFORCE on all bolts again for round 2 i want to apply PTFORCE .
It is not possible to use same contact surface for 2nd round . I also created new contact surface and then applied PTFORCE.
Is it possible to give two PTFORCE on single bolt in hyp V14 or higher?
